elettricorse
Inserito il - 18/05/2016 : 12:47:55 E-bike Complete Conversion - Kit Front wheel Q100 hub 36V 350W.
Motor Color: Black Power:350W Wheel size: 16'' Net weight(only the wheel): 2,8 kg Spoke holes:36 Fork size: 100 mm Front-Drving fit Rim/V Brake
KIT: Brake Grip, 6Mosfets E-Bike Motor Controller with LED meter (see photos below) Included all the cables. It is compatible with sensorless and hall sensor motor It is suitable for all our QQ-M93F-R and QQ-M85F and E-SWXK-F and E- CST-R and E-SWXH-R and E-SWXK5-F and E-SWXP-F and E-SWXP-R and E-SWXB-F 6Km/h button: When you press 6Km/h button and hold it, the ebike will run at 6Km/h speed as your walking speed, and you don‘t have to push the bike advance since it can run with your normal walking speed.
451,82 KB
313,45 KB
KIT 16'' - 299€ Iva e spedizione Inclusa.
Disponibili anche altre misure, per info e prezzi:
