 [RM o sped] vendo controller KELLY KBL 24-96V 150A
alex77roma
339 Messaggi
Inserito il - 17/07/2014 : 09:20:25  Mostra Profilo Invia a alex77roma un Messaggio Privato
Come da oggetto, vendo controller Kelly 24-96 volt da 150 ampere, compreso cavo J2.
Può essere alimentato sino a 120 volts,è completamente programmabile tramite pc e gestisce la frenata rigenerativa in modo progressivo.
Il cavo J2 è nuovo, mentre il controller è usato, ma in perfette condizioni di funzionamento.
Il controller è stato trattato con pellicola gommata nera plastidip.
Pagato qualche mese fa 390 euro, vendo a 290 spedito.
Attenzione: posso spedire non prima di 2 settimane, al rientro dalle ferie.
Seguono le specifiche tecniche:
KBL BLDC Motor Speed Controller
Kelly KBL programmable BLDC motor controller provides efficient, smooth and quiet controls for golf cart, go-cart, electric motorcycle, forklift, hybrid vehicle, electrical vehicle, electric boat, as well as industry motor speed or torque control. Motor speed controller uses high power MOSFET, PWM to achieve efficiency 99% in most cases. Powerful microprocessor brings in comprehensive and precise control to BLDC motor controllers. This programmable brushless motor controller also allows users to set parameters, conduct tests, and obtain diagnostic information quickly and easily.
Features:
• Intelligence with powerful microprocessor.
• Synchronous rectification, ultra low drop and fast PWM to achieve very high efficiency.
• Electronic reversing.
• Voltage monitoring on 3 motor phases, bus, and power supply.
• Voltage monitoring on voltage source 12V and 5V.
• Current sense on all 3 motor phases.
• Current control loop.
• Hardware over current protection.
• Hardware over voltage protection.
• Support torque mode, speed mode, and balanced mode operation.
• Configurable limit for motor current and battery current.
• Low EMC.
• LED fault code.
• Battery protection: current cutback, warning and shutdown at configurable high and low battery voltage.
• Rugged aluminum housing for maximum heat dissipation and harsh environment.
• Rugged high current terminals, and rugged aviation connectors for small signal.
• Thermal protection: current cut back, warning and shutdown on high temperature.
• Configurable 60 degree or 120 degree hall position sensors.
• Support motors with any number of poles.
• Up to 40,000 electric RPM standard. Optional high speed 70,000 ERPM, and ultra high speed 100,000 ERPM. (Electric RPM = mechanical RPM * motor pole pairs).
• Support three modes of regenerative braking: brake switch regen, release throttle regen, 0-5V analog signal variable regen.
• Configurable high pedal protection: the controller will not work if high throttle is detected at power on.
• Current multiplication: Take less current from battery, output more current to motor.
• Easy installation: 3 wire potentiometer can work.
• PWMable reverse alarm output.
• Remove fault code LED driver.
• Current meter output.
• Standard PC/Laptop computer to do programming. No special tools needed.
• User program provided. Easy to use. No cost to customers.
General Specifications:
•Frequency of Operation: 16.6kHz.
•Standby Battery Current: < 0.5mA.
•5V Sensor Supply Current: 40mA.
•Controller supply voltage range, PWR, 18V-120V.
•Configurable battery voltage range, B+,18V-120V.
•Analog Brake and Throttle Input: 0-5 Volts. Producing 0-5V signal with 3-wire pot.
•Reverse Alarm, Main Contactor Coil Driver, Meter.
•Full Power Operating Temperature Range: 0#8451; to 50 #8451; (controller case temperature).
•Operating Temperature Range:-30#8451; to 90 #8451;, 100#8451; shutdown (controller case temperature).
•Motor Current Limit, 1 minute: 150A.
•Motor Current Limit, continuous: 60A.
•Max Battery Current : Configurable.
Modificato da - alex77roma in Data 17/07/2014 09:23:34
alex77roma
339 Messaggi
Inserito il - 05/08/2014 : 12:53:47  Mostra Profilo Invia a alex77roma un Messaggio Privato
Scendo ad Euro 250 compresa spedizione con paccocelere3.
alex77roma
339 Messaggi
Inserito il - 21/08/2014 : 15:34:11  Mostra Profilo Invia a alex77roma un Messaggio Privato
Ribasso a 230 euro compresa spedizione paccocelere 3.
alex77roma
339 Messaggi
Inserito il - 02/09/2014 : 22:18:47  Mostra Profilo Invia a alex77roma un Messaggio Privato
Venduto.
GianniTurbo
1898 Messaggi
Inserito il - 03/09/2014 : 10:54:49  Mostra Profilo  Visita l'Homepage di GianniTurbo Invia a GianniTurbo un Messaggio Privato
ARGH !!!! sarebbe servita a me!!!!
dannazione
frankpastello
857 Messaggi
Inserito il - 04/09/2014 : 20:37:41  Mostra Profilo Invia a frankpastello un Messaggio Privato
TROPPO TARDI.... stai perdendo colpi... al posto tuo cambierei in Nick con GianniAspirato!!! hahahahha....... la centralina è rimasta a Roma cmq...
frankpastello
