 Vendo BMS lifepo4 24S 72V 50/100A
GianniTurbo
1898 Messaggi
Inserito il - 07/04/2014 : 16:47:30  Mostra Profilo  Visita l'Homepage di GianniTurbo Invia a GianniTurbo un Messaggio Privato
http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&item=231197600949
GianniTurbo
1898 Messaggi
Inserito il - 28/04/2014 : 09:21:23  Mostra Profilo  Visita l'Homepage di GianniTurbo Invia a GianniTurbo un Messaggio Privato
http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&item=331186550835&ssPageName=STRK:MESE:IT
Bms 24s lifepo4
ovvero 24 celle da 3,3 V nominali
50/100Amper
50 continui, 100Max
Comperato in italia
NUOVO mai usato per un progetto di restauro di uno Scooter Elettrico,
poi ho comperato un altro BMS 16S
qui le istruzione del venditore, riferito ad un bm da meno celle
WIRING DIAGRAM
1. Connect the Balancing Wires: Please connect the black balancing wires from the battery's
general negative
end, one by one, negative-positive-negative... to the end, the red balancing wire to the general
positive end .
2. You also have to connect the other wires B- P- C- (shows on the second picture)
B- = Battery pack - P--= Discharge - C- = Charge -
Battery pack- (3-in-1 black wires): you need to connect the black wires from the "B-" on the
BMS to the battery's general negative end.
Discharge-( 3-in-1blue wires ) :You need to connect another red wire yourself to the battery's
general positive end, the 2 blue wires and the red wire will be one pair of discharge wires, which
should be connected to your controller.
Charge- (1 yellow wire): You need to connect another red wire yourself to the battery's general
positive end,, the yellow wire and the red wire will be one pair of charge wires, which should be
connected to your charger.
Modificato da - GianniTurbo in data 28/04/2014 09:25:20
